ok so iv been doing a custom pc and been playing around with air flow and this is what iv got im over clocking (so far up 2 3.2gh) and running a temp around 49c (104f) i was thing of putting a 120mm fan in bottom of case was thinking is it really worth doing?? or am i just be wasting my time?
I don't think anyone can pin down a specific amount of degrees C drop for adding the fans.
The key to keeping the components inside your case cool is having proper airFLOW. The debate between more intake/exhaust is never ending, but what is agreed upon is that more intake is less dusty assuming your intake has filters on them. That said, the rule of thumb for most cases is:
tbh after a certain point adding case fans and high rpm fans gets to a point where it does less and less as you can only get the air going through the case so "cool" it can never be cooler than ambient temps.. what is the word... diminishing returns, yea. i mean doing more will cool it more but to what extent is unknown..
