Hello,
I have been working on getting the maximum cooling from my PC. Right now everything runs at really good temps but summer is coming and i know my temps will start to creep up. The room i am in will get hot this summer, Portable AC unit is used, but it only keeps the room just bearable. I have also noticed the RTX 2080 runs much hotter than my previous 1050ti which brings me to my concern.
See Picture of Current Setup
With this im pulling heat from that video card thru the radiator.
What im debating on doing is adding a duct pulling air from the top connected to the radiator. To avoid pulling the hot air from inside the case or being how close intake and exhaust are on the top would this just create a heat loop and counteract any benefit?
Would this setup be beneficial?
Thanks for your advice/opinions.
Vuta
Vuta
