- Dec 13, 2010
Hello everyone,
I have a newly built computer and the only time the fans are quite is at idle. Whenever I run a game the fan noise goes way up. Is there a way to get my computer quiter? Ive listed my comp specs below. I even have all the internal casing fans set at low. Any help is appreciated. Thanks!
case = Antec Three Hundred Illusion
mobo = GIGABYTE GA-870A-UD3
vidoeo card = SAPPHIRE 100315L Radeon HD 6850 1GB
pcu = AMD Phenom II X4 955 3.2GHz
ram = G.SKILL Ripjaws Series 4GB (2 x 2GB) (PC3 10666)
using CPUID hardware monitor I found these temps:
mobo temp:
tmpin0 = 36 C
tmpin1 = 43 C
tmpin2 = 80 C (northbridge - from my understanding this is normal with the GA-870A-UD3?)
cpu temp:
core0 = 45 C
core1 = 45 C
core2 = 45 C
core3 = 45 C
harddrive temp = 28 C
video card temp = 52 C
These are the temps when playing a game. Idle is pretty much the same temperatures though (within about 3 degrees C). I looked into manually setting the fans through MSI Afterburner/EVGA Precision but I don't want to create a possible instability. Side note - I'm also using the stock heatsink.
mobo temp:
tmpin0 = 36 C
tmpin1 = 43 C
cpu temp:
core0 = 45 C
core1 = 45 C
core2 = 45 C
core3 = 45 C
