- Jan 18, 2014
- South of Boston, Ma. USA
The plan was to build a new setup using the Phanteks Enthoo Primo in white. But after reading way too many complaints of poor customer support and damaged product I decided to go with a Mercury S8 from CaseLabs. I have also purchased the pedestal and this is where the radiators for the GPUs will be kept.
In the pedestal will be 2 360 rads parallel to each other. I don't believe it will be necessary to run the rads in push/pull, so there will only be one row of fan on each. The question is about the direction of the fans.
1. A cross flow, meaning one rad pulling in fresh air then through the case and out through the other radiator to the outside. (kind of like this idea the best)
2. Both pulling in fresh air.
3. Fresh air coming in the front and exiting through the radiators to the outside. (this seems like the worst scenario to me)
All opinions are welcome & appreciated, thank you.
