Hello Everyone!
I was wondering if maybe you geniuses could help me out with an airflow/dust problem.
I recently build a Hackintosh in the corsair 650D (3 weeks ago) and I'm already seeing a dust build up.
I was thinking about dust filters but then I was reading that they will severely mess with my temps.
I have the Stock (replacing ASAP) 200mm Front Fan (Filtered with Stock Filter) Blowing air through the front, dual 140mm Cougar Fans exhausting out the top and then my intel radiator fan Exhausting out the back. My psu also is blowing out the back but this doesn't affect dust seeing as though it's upside down.
I've attached a few pics to give you guys a better look at everything.
I would really appreciate some feedback on this air-flow setup. Is this optimal? What would you change? Should I add Filters? Where? etc.
I look forward to seeing your replies!
Thanks Guys!
Levitys
Thanks Guys!
Levitys
