- Jan 11, 2012
- North Carolina
Ok, I have a few questions.
First off, is there any difference on whether you mount a dust filter in front of or behind a fan? I have the Antec 300 case, so the front fans have the filter in front, but I have a fan on the side with a filter behind the fan because I just couldn't get it to work in front. I know that filters block some of the airflow, but does it make a difference if the fan is pushing or pulling it through the filter?
Secondly, I'm assuming the air is limited by the most restrictive point, but I'm wondering if I'm wrong and if it may be cumulative. For example, if the filter blocks more airflow than the the hexagon mesh on the side of my case, will removing the mesh make a difference at all?
Last, what about turbulence? I'm assuming this is the opposite of the previous question and that it is in fact cumulative, so would removing the mesh and leaving the filter remove some of the noise, or would it be exactly the same?
I was considering doing some mods to my case and removing all the mesh. Mostly to help reduce noise so the last question is in fact the most relevant to my plans. The front mesh looks especially constricting, and I'm that's also where the most of my turbulence noise is coming from. I don't hear the fans running at all, only the sound of air rushing through the mesh/filters.
