- Mar 4, 2003
Hey all,
I have the computer listed in the subject and in my signature. An Alienware Aurous R11 3080 i9 10900k. When I load optimized defaults the computer locks itself at 4.7ghz. It doesn't go above ever. If I put the power on balanced it will temporarily go to 1ghz etc, but once I do anything it goes right back to 4.7ghz. Which I know is the power saving feature. If I put the power to performance it stays locked at 4.7ghz.
My question is. Shouldn't it be bouncing from 3.7ghz to 5.3ghz based on core usage? It never ever does this. This is very frustrating because I just want the cpu to work as it was originally designed. Bounce from 3.7ghz to 5.1/5.3ghz based on usage.
Any help would be greatly appreciated. Again. I loaded optimzed defaults. Hyperthreading is enabled, speed step is enabled, speed shift is enabled, xmp1 profile is enabled. overclocking is DISABLED. I just want it to act as intended.
*UPDATE*
Even when running cinebench single core it locks all cores to 4.7ghz. It's doing no stepping or focusing on utilizing less cores to maximize performance.
For refrencee
*UPDATE*
For refrencee
