I just got a new Alienware Aurora R7. I read different forums and found out that some memory modules were not compatible with this motherboard. There was on sale on memory below for me to test but both are compatible.
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231892
https://www.rakuten.com/shop/adata/product/AD4U300038G16-DS10/?sku=AD4U300038G16-DS10
This is the spec from Dell
Memory specifications
Slots
Four DIMM sockets
Type
DDR4
Speed•
2666 MHz•
Up to HyperX FURY DDR4 XMP at 2933 MHz
These are 2 different clock speeds. I am using both in it now. When I use seperately the G.Skill or Adata the xmp memory is enabled in the bios. If I put it together the XMP is disabled.
Now I believe the motherboard is underclocking the Adata. What benefit do I get from getting 2 set the same vs 2 set not the same?
If I am benefit from same memory then I will go for this:
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231937
Slots
Four DIMM sockets
Type
DDR4
Speed•
2666 MHz•
