- Mar 13, 2011
- Chaparral, New Mexico
Alright guys I have contemplated on building a loop for my rig, after much reading Iv decided I am ready to start getting parts togetehr and get this build going. Money wont be a big issue, income tax will be here soon
Rig is in sig, only difference will be the addition of another 6950 which I plan on putting both under water. Just want to get rad and block figured out so I can get the best adequate pump for it.
My propsed loop flow is as follows...
Res-> Pump-> 360mm top mount rad-> CPU Block-> Rad?->Both GPU Blocks->Res
Im not sure what rad to go with after cpu though, a beefy 120 on the back interior. Not sure If I want to mount a rad via exterior. So I thought maybe removing the front hard drive bays and mounting a 240mm rad there so as water leaves the cpu it goes into this rad and then into the gpu's.
I know this would create lower temps but the added size in rad, and hose length leads me to believe I might need something better than a D5 Vario.
Components im looking at, havent decided on fittings or hose as of yet:
