- Nov 1, 1998
Today from Alphacool we get the chance to look at a very new product to the market, the Eiswand. This is a standalone watercooling kit with everything you need to get started! This kit is even friendly to those with small factor cases, as the radiator/pump/reservoir are all external and contained in one housing. Enough banter, let's dig in and take a look at this kit!
Specifications
As with everything Alphacool makes, all the watercooling components are made of copper/brass. The radiator used here is their NexXxoS XT45 360mm, which is 100% copper construction and very well known on the market. The water block in use is the NexXxoS XP³ Light which has a copper base plate and black acetal top. Tubing, fittings, quick disconnects, and fluid are all supplied as part of this kit as well.
Click here to view the article.
