- Sep 25, 2003
- Mesa, AZ
Man... I'm REALLY itchin' to oc my chip. I have a dilemma though... My sytem temps are a little on the warm side. Basically I wanted to get a little advice from you guys to see if you all think it will be safe to oc my p4 2.6c.
My system temps are:
Case: 27-30°C idle / 30-32°C load
CPU: 37-40°C idle / 48-50°C load
This is my case.
Here's my cooling setup:
-1 80mm intake - bottom front (Thermaltake SmartFan 2 75.7 CFM)
-1 80mm intake - side panel (Thermaltake SmartFan 2 75.7 CFM) - ducted to my hsf
-1 80mm exhaust - top rear (Thermaltake SmartFan 2 75.7 CFM)
-This is my PSU.
I've got a Thermalright SP-94 mounted w/ Arctic Silver 5. The duct only has 1 fan, the duct is connected to my hsf w/ a fan shroud.
To answer your preliminary questions:
-Yes, my SP-94 is mounted correctly, I've remounted 3 times.
-I used very little AS5, the amount specified by Arctic Silver. A small dab, just about (slightly smaller) than a grain of uncooked rice. I also tinted the bottom of the SP-94 w/ AS5.
-I didn't lap my SP-94, but it came pretty flat. No visible ridges, and the base was pretty shiny.
-There was no original thermal pad to remove on the hsf.
-I've been running all my fans @ or near full speed.
-My case is pretty dust free. I use fan filters like this on both my front and side (ducted) intakes. I also blow my case out w/ compressed air, and clean out my hsf fins about once a month or so.
I'm liking my system temps so far. They're a little cooler than before, w/ my lower airflow setup. I like the fact that my case doesn't really rise in temp under a full load. I'm a little leary of my CPU temps though. They seem a little warm, so I'm pretty hesitant. They are warmer than what I've seen from other people who have similar setups to me. Given, I am in Phoenix, AZ, and it is 80°F outside in January right now. My apartment is usually between 70-80°F. I've seen my CPU get as high as 52°C under full load when my room temp was around 80°F.
My thought is, that my temps are high due to environmental conditions. I think I've got an awesome cooling setup for my (very limiting) case. Is there anything else you think I could do to improve my cooling. My rig is sitting on the floor, away from any vents (heat or AC). It's not by any windows or doors either. It's in the corner of the room, which seems to me that it might get poor circulation, but I don't really have room to move it elsewhere in my apt. Are there any ideas that you may have??? I'm also trying to consider what may happen when it's 120°F outside in the summer, and around 85°F in my apt. Would a humidifier in the room help/hurt at all??? Is there any good way to get more cool air directly to my computer???
Any suggestions/opinions would help me out a lot guys!
This is my case.
-This is my PSU.
