- Jun 13, 2005
Hello, I haven't built an amd machine for a while however I have an aging 939 dual core that I want to update. As I shopped around for a cost effective option for a 2nd computer I'm noticing that if I do a cheap i3 or semi cheap i5 I see that intel is still up to their old tricks by changing the socket ever year.
When I look at AM3 options, I'm hearing there is a potential that AMD's next cpu may use that same socket so I'm thinking of getting something fairly inexpensive cpu wise with amd instead of intel and then dropping in a new cpu later.
Am I on the right track here? Would that work with the new cpu's coming out? Also if you don't mind what would you recommend as an easy overclocker board and cpu wise that would have a lot of overhead. I'm looking at the 965 BE's right now.
Thank you in advance.
