Hi everyone at ocforums, I was wondering if anyone could help me out with this dilemma. I'm having problems changing any settings under the PWM settings tab which is where all the voltage settings are located. When i enable it or change anything at all i get locked out resulting in cmos reset every time. Changing any other settings seem to be fine in bios, except those specific settings. Much help appreciated thx!
Currently on auto the settings under pwm are:
CPU VID: 1.280
Dram volt: 1.950V
SB PLL 1.2v Voltage: 1.2v
NB core: 1.250v
NB PCIE:1.120v
NB HT Volt:1.270V
__________________
Recent changes:
Changes from old setup:
Replaced all stock case fans with arctic cooling 120 mm pwm fans rated at .13a I have 5 of these fans in my case i have 4 of these fans daisy chained in sets of 2 occupying in 2 fan headers and 1 using it own fan header.
Reseated, reapplied the paste with arctic mx 2 on NB and SB to reduce temps
Changed OS to Windows 7 pro 64bit
Flashed bios to 4/21
CPU VID: 1.280
Dram volt: 1.950V
NB core: 1.250v
NB PCIE:1.120v
NB HT Volt:1.270V
__________________
Recent changes:
