- Sep 29, 2004
Sorry Mj i wasn't being specific enough.... i was going to say unless you're using extreme cooling but
Lol, just one of those things dude. The number of times I'm thinking one thing and manage to type something else entirely is crazy
The loaded temps are wrong too...
So is your 14c idle temp...
Motherboard sensor on ASUS is spot on +-2-5c, confirmed with K-Type bead probe. The built in sensor in the CPUs are -20c below real. Gigabyte boards seem to read 5-10c low as well on their motherboard sensors.
Normal idle values for AMD FX are 30-40c depending on if you are stock with power saving features enabled or CPU is overclocked substantially.
Yeah, CoreTemp shows mine at 35C idle, after I told it to adjust for and add an additional 20C
