**EDIT:
Using APU stock fan cooler for AMD 980 BE CPU, also tried a heatsink for AM3/AM3+/FM1 CPU.
With ALL power features disabled tempatures idling around 55C
With ALL power features enabled and lowered CPU voltage -.25V idling around 40C (with ANY load the tempatures would jump to 50C+)
Happening during the night with all power features disabled -- and during the day time with power features disabled
AMD 980 BE
Gigabyta 990XA-UD5
Gigabyte 7850 OC Edition
Phantom 410 (Stock Fans)
G Skillz 2133MHz 9-11-10-28 (Set to 1600 until I get a better cooler/stable system)
**Main question, if reapplying the thermal paste correctly, which I read up how to do online, does not correct the problem should I RMA the CPU? and if I am to replace the CPU should I go with the FX-series, I have been trying to aviod them at all cost.
Please get back to me ASAP before I am unable to RMA the CPU!
**OLD:
Okay.. so I just got done building my new system. I purchased the AMD Phenom II 980 paired with the Gigabye 990XA-UD5 motherboard with 2133 RAM (SET TO 1600MHZ FOR THE TIME) with a SSD and WD 7200 hard drive.
I am using the stock cooler from my APU, the temps where 55 - 60 idle.. so I reapplied some Artic Silver 5 and the temps stayed the same. I set windows power to power saver, turned on cool & quiet and CE1.. the temps did drop to 40C but with any load at all they would instanlty jump back to 55-60C.. UGH! I tried changing to a lower end CPU cooler which is working the same with Artic Silver 5......... also I have the volts down -.25 on the CPU and NB volts.
Do I have a bad chip? My room is above room tempature.. but my case is the Phantom 410 with 4 fans... great cable management. I have never had this problem with any stock cooler. EVER. I do plan on getting a H100 when I can afford it.. but is there an issue with the chip? Stock VID was 1.4V..
Thanks..
Joel Howard
AMD 980 BE
Gigabyta 990XA-UD5
**OLD:
Thanks..
Joel Howard
