From what I posted in 'ssjwizards' thread; you all know I had been sitting on my own results for months really. I took my data and made the graph. (freeken job for a red-nake). I posted to 'add to' what ssjw was seeing. Then 'caddi daddi' weighed in with his response that was very identical to what we were seeing and saying about the Bulldozer cpu. I think 'anonaru' has registered similar. Without the stepped testing a review site would never get this type of 'trail' out to the average Joe Six Pack user.
There are LIGHT YEARS difference in what the OP is using for cooling and what the other 99% of users come in here with asking for help to do a simple overclock. I merely told "P8ntballjunky06" that he did not have enough Vcore and he upped the Vcore without whining about raising it and his FX-8150 went on up some more.
A great difference in the calibre of motherboard between what "P8ntballjunky06" is using and most others, since he went for the gold to begin with.
Now the FX-8120 I had was P95 Blend mode stable @4.8Ghz for TWO hours. But it was using really really good water cooling. The Vcore for me was close to 1.55V. That is a lot of Vcore to get Real Stability."P8ntballjunky06's" FX-8150 seems that little bit better than an FX-8120 as we are also beginning to be able to see.
My data that I added to what "ssjw" was being set on because most people cannot hear. "P8ntballjunky06" seems to be better equipped and has a very good FX-8150 that raises him into the top 10% of users or so. Far above what is generally in the AMD CPU Forum section asking for help. Of course we have not seen any results of "P8ntballjunky06" trying to P95 Blend at his latest CPU Mhz levels. He maynot be truly stable up there. I feel he will give a real go though and stands a chance of making it to stable. But those speeds are not doable by the other +90 odd percent of posters in this forum section.
What I wanted to be able to show the 90 percenters is that you really can get 95% or maybe even a little more out of Bulldozer 8 core processor before you HIT those last two BIG voltage steps that also bring on the HEAT.
Straining to get 4.5Ghz on an 8 core seems pretty senseless in the LIGHT of day. I can use my FX-8120 below 4.5Ghz with almost 0.15 LESS Vcore than what it takes to get to 4.8Ghz stable. For me that is huge chunk of lessened VCore. Big lot of lesser VCore. Plus a huge lot of LESS heat.
That is what I wanted the 90 percenters to see. The overclock they could reach on a well cooled case with a CM 212 EVO coooler was PLENTY for using about +95% of the FX-8120 and FX-8150. But what is the old addage about the hand-writing on the wall? Well the writing is here, just unseen.
By the way "P8ntballjunky06" nice system man and
to the Forums. RGone...ster.
