Mine cpu's default voltage is 1.3 V but mine cpu even at %100 usage runs at 1.248 V.So I upgraded bios , changed PSU , loaded default options at bios but just nothing.
Do you mean its dead now. Doesn't work at all or the problem isn't fixed?
It's normal for voltage to drop under load like unless there is an LLC (Load Lind Calibration) offset. Many of the older motherboards like that did not have LLC.
Its not uncommon for the voltages to be a little off and on top of that software voltage reading are not 100% accurate. If it works don't worry about it.
