- Nov 19, 2010
Hey Overclockers!
I ended up on this Forum while I was looking for the topic "Unlocking AMD Athlon II X3 445" and I started to like this Forum also.
Considering that I used Google and the Search Function on here, I couldn't find my answers so I hope I'll get some assistance here.
Starting over, my system set up:
First over, I have slightly overclocked my CPU by setting the BIOS this way:
So far, this config is working stable without doing any problems.
Have checked the core temperatures also and they went up just by 1°C - 8°C, nothing to worry of since the highest temperature registered by CPUID Hardware Monitor was 25°C (77 °F).
When I've checked CPU-Z, it shows the following info:
Stepping 3
Revision BL-C3
What shall the "BL-C3" mean?
Also, I have been having troubles with unlocking my CPU. I've read everywhere that I just have to simply enable the ASRock UCC in BIOS and that's it but I've tried it like 5 times and the Unlocking failed. I've tried to set up the CPU Voltage up to 1.40V (max I dared to) and the system still didn't boot up nor showed up the POST screen nor anything.
After saving the BIOS Settings with UCC activated, the system turns off and restarts after few seconds but it shows no signal. It doesn't boot!
Is there any possible solution to fix this? Or is my 4th core and L3 CPU Cache defect at all? Thought I would have some luck since it's a C3 Step CPU.
Thanks for any help guys!
Here the screens from CPUID HW and CPU-Z:
http://img28.imageshack.us/img28/298/cpuf.png
Regards,
xXDangerous
Edit: The CPU-Z show's the Idle CPU Frequency, not the real one which should be 3,3GHz ...
CPU
AMD Athlon II X3 445 3,1GHz (Core: Rana; Stepping: 3; Revision: BL-C3)
Motherboard
ASRock N68C-S UCC (BIOS v.: P1.40)
Power Supply
350W ATX Power Supplier 20pin
Video Card
NVIDIA GeForce 7025 / NVIDIA nForce 630a (OnBoard, 256MB shared memory)
Memory RAM
Kingston DDR3-1333 (667 MHz) 2GB (1x Module)
CPU Frequency 215 MHz
PCIE Frequency 100 MHz (left untouched as using onboard card)
CPU Multiplier x15.5 (max) (3332 MHz)
Processor Voltage 1.3250 V (default)
NB Frequency Multiplier x10.0 (max) (2150 MHz)
HT Bus Speed x5 (max) (1075 MHz)
HT Bus Width AUTO
Stepping 3
Revision BL-C3
Regards,
xXDangerous
