Hey all, Back again with FX-6100 problems. I had a slight issue with energy saving mode cutting my computer off as the idle for the cpu was too low. I have since turned this off and computer works ok, but if i start going through webpages or applications too fast it stutters and music freezes. Only ever so slightly but very annoying. Also when on games i enjoy my motorsport simulators and it has a very slight stutter when coming out of any corner for milli seconds but very noticable ( tried on two simulators same issue) Frames per second are well into the 100+ range.
Previous Problem: http://www.overclockers.com/forums/showthread.php?t=706621
I have since upped Vcore to 1.35V and tried lowering the LoadLine Calibration as said by a user when the problem started. So i am guessing other auto features are wrong on the motherboard and after setting them all up manually.
PC SPECS:
CPU: AMD FX™-6100 Six-Core Processor 3.30GHz
RAM: Corsair Vengance 1600 MHz (4GB)
PSU: Corsair CX430
Motherboard: Asus M5A7BL-M/USB3
Graphics Card: Gigabyte 8800 GT
HardDrive: SAMSUNG HD103UJ 1TB
My BIOS settings:
Configure System Frequence/Voltage
CPU Overclocking (AUTO)
Memory Clock Speed (AUTO)
GPU Overclocking (AUTO)
PCIE Overclocking (AUTO)
CPU Ration and Voltages
CPU Ratio (AUTO)
AMD Turbo CORE technology (AUTO)
CPU/NB Frequency (AUTO)
CPU Over Voltage: 1.3500V<- i changed this from (AUTO)
VDDNB Over Voltage 1.100V<- Changed this also from (AUTO)
LoadLine Calibrations (AUTO)=48% <- Have tried lowering it up to 35%
CPU Bios Page
GART Error Reporting (Disabled)
Mircocode Updation (Enabled)
Secure Virtual Machine Mode (Disabled)
Cool 'n' Quiet (Enabled)
Core C6 State (Auto)
Advanced Clock Calibration (Disabled)
Sorry total novice to AMD and Overclocking. I am just after getting it running how it should be out the factory. Then once its fully functioning maybe overclocking it. Thanks for the advice in advance.
PC SPECS:
PSU: Corsair CX430
My BIOS settings:
CPU Ratio (AUTO)
CPU Bios Page
