ok ok ok!!! Heres what we got. AMD 2500+ Baton proc. We put it out of the box into a A7N8X DLX ASUS mobo. After much cussing and ******* we ended up with the folling:
1833 to 2400. NO @%#^#!
That is water cooled and the pelt is going on tomorrow!
My Best Bud RAD MAN is the dude that makes it happen. We are also running at 200X12=2400 isn't 400fsb insane and we will get more even if Rad man has to volt mod this new board! He will probably do it anyway while I am asleep or something anyway! (I believe but don't quote me the stepping is ACGGA0302,if I am wrong I will post the correct on a new thread). We are easily getting 570 mhz over stock, and I believe Rad Man is capable of a few more hundred after the 226w pelt is in! -5 below C is coming soon!We will post Pics and stuff as soon as we are done, you all will love this thing! I know we do! We really appreciate you guys! You all are the heat! We always check here when we need the real deal info on getting our stuff to work right! A BIG THANX TO ALL YOU DUDES!!!!!
SYSTEM NEW BUILD ALMOST COMPLETE (95%)
Custom Painted case w/ window and custom light effects.
ASUS A7N8X D mobo, BIOS VER. 1004
AMD 2500+barton 1833 cranked up to 2400mhz 1.875v 200X12!
OCZ LL, el DDR 3500 512m w/ copper heat spreaders @402mhz!
ATI 9500 pro bios flashed to a 9700 pro Radeon Graphics card
RAD MAN will have this volt modded before I wake up he he
Antec pp402 400W (pots have been cranked for more voltage for the 3.3 and 5 volt rail).
Separate meanwell power supply for the 226w pelt. (tomorrow!)
SB audigy2 with live drive sound card
600w SONY 5.1 surround sound system
19" (18.1 viewable) Sony Flat panel monitor
13" LCD Sharp Flat panel TV mounted on case for additional viewing pleasure! It folds up flush on case when not in use hehe
60 gig 7200rpm HD, 52X24X52 CDRW
Oh oh oh ehhhh It's Water Cooled with a in the case Water System with MAZE2 copper block with pelt mount, and Rad Man also made... Thats right, MADE! custom water blocks for the North Bridge and the Graphics card! He is the heat eh?
We will be building Custom systems similar to this for folks that just gotta have! We're the Kahoots Brothers! and our company is RED BOX INC! [email protected]
*"ENERGY STAR COMPLIANT we're NOT!"*
