kevinduke13
- May 30, 2014
- Rochester, NY
I'm new to overclocking, and i just got my new Thermaltake NiC C5 120mm CPU cooler and i want to overclock it from a 3.6ghz to 4.5ghz because i feel like my cpu is bottlenecking my gpu. Will my CPU cooler be enough for this task? All the help would be much appreciated! Thank you in advance
MOBO > Biostar TA970 Ver.4.6.4
http://www.newegg.com/Product/Produ...72&cm_re=Biostar_TA970-_-13-138-372-_-Product
CPU & Cooler > AMD FX-4100 Zambezi 3.6ghz (goal 4.5ghz) / Thermaltake NiC C5 120mm CPU cooler
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
Cooler: http://www.newegg.com/Product/Produ...6&cm_re=thermaltake_c5-_-35-106-216-_-Product
MEMORY > G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Produ..._DDR3_1600_(PC3_12800)-_-20-231-428-_-Product
POWER SUPPLY > RAIDMAX Blackstone series RX-700AC 700W Continuous Power ATX12V V2.3 / EPS12V V2.91 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Produ...ctive_PFC_Power_Supply-_-17-152-042-_-Product
VIDEO CARD > SAPPHIRE 100364-4GBF4L Radeon R9 270X 4GB GDDR5 Video Card
http://www.newegg.com/Product/Produ...X_4GB_GDDR5_Video_Card-_-14-202-078-_-Product
HDDs/Optical drives > Western Digital WD10EZEX 1TB 7200 RPM
http://www.newegg.com/Product/Produ..._WD10EZEX_1TB_7200_RPM-_-22-236-339-_-Product
SOUND DEVICE > Onboard
O/S > Windows 7 Ultimate Edition 64-bit
Case > RAIDMAX Raptor ATX-823BR Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Produ...279&cm_re=raidmax_case-_-11-156-279-_-Product
