Upgrade from 2500k to ryzen help make sure I don’t screw up
baggedmazda
I think the time has come to upgrade from my old 2500k based system to something newer. I will be saving my power supply, rx480 and storage.
As I have parts figured right now
CPU: ryzen 5 1600
Mobo: Asus - STRIX B350-F GAMING ATX AM4 Motherboard
Cooler:https://www.bhphotovideo.com/c/prod...lw_d24m_a20pc_r1_masterliquid_ml240l_rgb.html
This keeps jumping in price so I starting to question this but would love to finally do a water cooled cpu
Ram:Team Dark Pro 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model TDPRD416G3200HC14ADC01 http://www.newegg.com/Product/Product.aspx?Item=20-313-711
Nvme.2 for boot drive: WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s M.2 2280 Solid State Drive - WDS500G2B0B http://www.newegg.com/Product/Product.aspx?Item=20-250-091
Case:https://www.superbiiz.com/detail.php?name=CA-S340WW2&c=CJ
Really looking to move out of my original nzxt phantom it’s pretty dated at this point and it’s too big any more for me
Monitor:Acer ED273 Abidpx 27" Curved Full HD 4ms (GTG) 144Hz Widescreen LCD/LED AMD FreeSync Gaming Monitor HDMI DisplayPort DVI http://www.newegg.com/Product/Product.aspx?Item=24-011-165
Ready to move on from my decade old 22in monitor and stay at 1080p so I can at least keep some decebt FPS this seemed to be a good middle ground with the large size I wanted while not being stuck at 40 FPS because my gfx can’t keep up
I think that’s everything I have that I need right now
and the cooler supplied is often good to 3.8 and more and that's about the top anyway.
I questioned that also but didn’t know if the price jump would be worth it going to say a 2600 and then having to go to a 470 mobo that I really won’t need all the features
- - - Updated - - -
I’m probably not gonna be looking for huge overclocking just nice decent low temps
Why not go to Ryzen 2 instead?
absolutely. the price is the same for the cpu and there are some really nice combo deals at newegg even with a x470 mb. invest in the latest rather than a gen older proc. the 2600 will come faster out of the box according to techspot.
https://www.techspot.com/review/1614-ryzen-2600/
i would check this combo out. it looks really solid and the price is definitely right.
https://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.3777051
seeing that combo deal is giving me the itch...lol.
A huge clock for ryzen tops out at around 4.2 from what I have seen on the nets with 4.0 being a very good number.
I have not looked at ryzen 2.
thats the combo deal i have been eyeing actually lol looks like i will go with that. is that cool gonna be good enough or should i stick with a good trusty reliable aftermarket air cooler i think that is about the only thing left i am really unsure on
I would suggest getting the 2600X for two reasons. All core boost is around 4.0 GHz +- 50 MHz alleviating the need to overclock and the supplied cooler will keep it under control just fine even up to 4.2 all core from my testing. Use the $70 you save from that cooler and put it toward the CPU/mobo
Also that WD Blue drive is a SATA based M.2 not an NVME based M.2.
board says it suppots m.2 sata.
AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M key, type 2242/2260/2280/22110 storage devices support (SATA & PCIE 3.0 x 4 mode)*5
2 x SATA 6Gb/s port(s),
AMD 7th Generation A-series/Athlon™ Processors :
1 x M.2 Socket 3, with M key, type 2242/2260/2280/22110 storage devices support (SATA & PCIE 3.0 x 2 mode)*6
AMD B350 chipset :
4 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
am I missing some info?
Nothing serios C_D , OP said NVMe but the drive in question is SATA and doesn't run over PCIe. Just a poor choice of words on their part.
good, let's not have any more new connectors or protocols, my brain is burnt now with nvme, m2 sata, u2, esata.
Yeah not so familiar with all this new tech stuff.
Ended up getting a 500gb mushkin nvme and going with the 2600 and gigabyte combo.
should be a nice upgrade from the old 2500k
