We Ballin' Yo
I would call that a damn good settle. Now I'm wanting a new case, does it ever stop?
I don't think it does. I'm okay with that, though.
Just curious, have you tried any other stability software aside from Aida64?? We generally recommend Prime95 blend to really push the CPU/memory set-up
Initially, when I had the system set up on my test bench I attempted to run Prime95 Blend on everything stock with no setting modifications or anything and it would fail on several cores every time. I did attempt to run both the 32-bit and 64-bit versions of Prime95 and to no avail, it would fail.
I then went onto a forum asking around and a lot of people were having issues with Prime95 and some weren't so it just turned into a
fest.
I did run IntelBurn also - and ran that for over 12 hours on the 5GHz OC without fail.
The memory was at the motherboard issued 1333MHz which I then put in the XMP 1 Profile for 1600MHz which didn't change the stability of the machine at all.
For temps, if I'm going to be on for quite a while, I'll bump it down to 4.5Ghz because I can encode longer with even lower temps since 4.8GHz (for me) only takes 1.420V on the VCore. I'm kind of OCD about temperature and absolutely hate anything over 40C....and with the 4.8GHz OC I'm able to encode for days on end and not topple over 38C which I love.
5GHz is fun and all - but you really don't see a difference (at least I can't) between 5GHz and 4GHz (even with FPS
) in gaming to justify the harsh temperatures and voltages required to achieve those core clocks.
