OK guys, so I when people, and people still do today use the FX series of proccessers, people report to be having 1000 watts of power draw when not even running a demanding system.
Perhaps they (or you) are misunderstanding their system. They may have a 1000 watt power supply and maybe they don't know that it only draws full load when needed. I have a 1200 watt power supply, but when I measure the AC draw from the wall to the power supply, I am only using 217 watts at idle and when 100% cpu and gpu load it shows 297 watts.
And..not to mention, I thought the CPU 8 pin could only draw 150 watts of power?
I think the 150 watt rating is the TDP. If I remember correctly, on the manufacturer specs, the 8150 can draw 243 or 247 watts at full load.
On a side note, if the FX series had power problems this serious wouldn't something give? I mean AND would have to have some input in this. I know this topic is kinda irrelevant but I was just curious on what you guys have to say on this.
I think the architecture is too new for anyone to really be able to say, except AMD. I'm willing to bet AMD isn't being entirely forthwith about details, and rightly so if you consider that trade secrets can be leaked based on theorizing about published clues.
I wouldn't say the FX has a power problem. The only issue I've encountered is when I tried to get an extra 900MHz/Core overclock. 800MHz was and is just fine, with no apparent power issues.
However, it does seem that not all FX chips are alike. Some seem to be more solid than others. Some appear to be more persnickety.
In re Post #3:
I guess I should've rephrased that, my bad. You've never heard of people reporting outrageous things? I was just giving an example.
I've heard outrageous things about every chip since the 8086. A few instances of weirdness, sure. Keep in mind, bad things will be repeated over and over, almost 100% of the time. Good things are usually not mentioned.
If somebody didn't repay money they borrowed, you'd tell everyone. If they repaid you on time, who would you tell?
