First...if you're really wanting to OC your rig...Do it the right way in BIOS.
As for the issue with AOD. It's that way on my rig too (which is also from CyberpowerPC) yet in BIOS all settings are adjustable. CyberpowerPC systems are fully OC'able through BIOS. The systems they sell are are not locked or crippled in anyway.
(and god I should not have gotten windows 8).
Sometimes the software that comes with the board works out even better than AOD. Just gotta do a little trial and error.
AMD is NOT going to dork over their OEMs; so if the setting you wish to change in AOD is actually locked out in the bios then it is locked in AOD also. Cyberpower has NON-adjustable FSB/HT Ref clock in bios so it is NON-adjustable in AOD also. They are not going to let you overclock an OEM system and have issues with the OEM.
RGone...
AMD FX 8350 @ 4.0ghz + Gigabyte 970A-D3 + what aftermarket cooling?
Mini, Yo welcome to the forums! As said previously, we will usually refrain from using windows based programs for overclocking, including Overdrive. This post is a good starting point for you to learn the inns and outs of what you will need for overclocking the Fx 8350. What heatsink is on the CPU now? Also download Hwmonitor "non pro" version and run Prime 95 for 20 minutes with it open and post a sreen shot here using the in forum attachment tool. This way we have a reference point to see where you are at, at stock settings. Just so you don't get your expectations too high, that motherboard isn't one of the better ones to be overclocking that chip on. It will probably be the limiting factor in your overclock.
This^^^ I purchased two systems from Cyberpower, before I decided to start building myself. They do not modify the BIOS at all and any overclocking ability the motherboard that is in the system has will still be in tact.In an effort to provide a bit of info regarding Cyberpower PC systems. First the are NOT OEM like HP, Dell, Gateway etc. They are custom built systems, using the same parts as most here have purchased. The difference is Cyberpower PC builds the system instead of you buying the parts and building it yourself.
All Cyberpower systems can be OC'ed through BIOS just the same as if you went and bought your mobo from MicroCenter, New Egg etc. Their systems are NOT locked in any manner.
As for the OP's issue with AOD, forget using it and read up on OC'ing through BIOS. Honestly, I doubt that the guys (and gals) the bench use software to obtain the super OCs they get (not that it might not be possible to).
Actually, when pushing the limits on extreme overclocking, it is quite common and recommended to use windows based or board based changes. We may be able to get to windows at X.xx GHz, but cannot further, so you boot towards that limit and push up with windows apps.Honestly, I doubt that the guys (and gals) the bench use software to obtain the super OCs they get (not that it might not be possible to).
read the Amd FX processors unleashed| a guide to performance tuning with AMD OVERDRIVE and the new AMD FX processors.
you will read that some settings require a reboot.
example, page 4 paragraph 5, CPU/NB multiplier requires a reboot (it can not be adjusted on the fly)
