Don't update AOD, then. Or, if you're referring to Windows 10 updates just reinstall AOD. It doesn't take long. Software overclocking isn't the best choice, but AOD is about the best one I've used. I used AOD to find my settings then entered them in the BIOS and fine tuned. I don't know of another program that works as well.
