Now if I put too much on, wouldn't the excess ooze out of the sides?
Not a problem at all. Had you left it the way it WAS, then that was not ideal. Just be careful cleaning it otherwise it'd be an expensive learning lesson.
What do you mean by left it the way it WAS. I haven't changed anything, and to the best of my knowledge the thermal paste had no viscosity but I will do it again anyways.
hello again, well and I have almost 1 year with this configuration and if I used prime95, Stability test of AMD overdrive and leave a crazy night on prime95 + cinema 4d render active. so far I have not had any problems. with it. play and work with this configuration, I can send more and screenshots if needed
