- Dec 14, 2010
Admittedly, it's been a long time since I ran an Intel rig in my own home and had the ability to test it at will, like as in 5-6 years. The last Intel I owned was a Pentium III 866MHz. For the past five years or so my main (and only) desktop rig has been my trusty AMD socket 754 single-core with a 1.8GHz Sempron 3000+. So, you can probably imagine how me venturing into the Intel section of the CPU forum is kind of the same as visiting a foreign country.
Today I went about testing some socket 775 hardware I had here, just because I wanted to see if it all would play nicely together given it was all obtained in used condition and some of it was untested when I obtained it.
First I discovered that apparently HWMonitor can't read the right temps on a C2D chip, which annoyed me a bit since that's what I normally use, and so then I had to go download RealTemp.
After I got that out of the way though, I discovered that this thing really does run cool; okay, that's a lie, I actually discovered that before I downloaded RealTemp, because I was putting my hand on the heatsink with HWMonitor going and saying to myself "there's no way it's that hot." Such was why I decided to download this RealTemp thing, since I've overheard people from the Intel camp talk about it in HW reviews in various places, to see if the temps the two report would differ, and they differ greatly.
The second thing I discovered was that these Intel chips apparently cool down really FAST. I literally had this thing at full load and it peaked at 50°C, less than two minutes later I had the heatsink off and after putting the back of my hand to both the heatsink and the processor I discovered they both weren't at all warm to the touch, if anything they were room temp or less. Now, the AMD socket 939 rig actually has its load temps about the same, but it seems to take longer to return to the normal idle temp range.
You might be asking yourself why I removed the heatsink that quickly. That would be because I neglected to put any paste on the heatsink when I first installed it, and proceeded to forget that fact. Plus when I saw HWMonitor showing temps of 60°C on both cores I was concerned I was about to fry the processor, little did I know at the time though that it was 10°C higher than the actual temps. A secondary reason was that I was wondering just how hot one of these would get without any paste on the heatsink, and how much cooler it would run with some paste applied.
Another thing which surprised me was the speed at which this chip was able to complete a run of SuperPi 1m. Now, my AMD socket 939 rig with a dual-core A64 4200+ 2.2GHz chip running at all stock speeds can complete a run in around 39-40s, this C2D E4400 (2GHz) socket 775 chip completed it in 28s. In all honesty I expected my 939 rig to beat the 775 by at least a little bit, given that it does have a 200MHz advantage in clock speed, or at the very least to give the 775 a run for its money. That didn't happen here though, as the result was quite the opposite with the socket 775 completely trouncing the 939 in nearly half the amount of time.
These tests were performed with both machines having stock cooling in the CPUs, and running 2GB of value ram each, with the 939 running with a SATA HDD and the 775 using an IDE (it was what I had handy, and it already had a stripped down OS loaded onto it, good enough for testing purposes anyway).
Now, I'm impressed by what I've seen today, but I'm still not sure it justifies Intel's price tags.
