- Jan 24, 2015
Hello all, I’m having a bit of an odd problem that seems to go away for a week and then return. Last month I begun looking into overclocking my Phenom II. The guide I found most helpful and was the one I followed was Dolk’s guide (http://www.overclockers.com/forums/showthread.php/596023-Dolk-s-Guide-to-the-Phenom-II) . Since this was my first time overclocking I didn’t want to push it too hard so I only overclocked it from 3.2 to 3.8 Ghz by making my CPU ratio 19 and bumping up the CPU-NB and HTT to 2200. I ran tests with prime and everything seemed okay, my temps didn’t go above 40 degrees and no crashes. I ended up sticking with those setting, they seemed to work just fine, my games ran better and I didn’t have to change any voltages.
Okay so about two weeks later my power supply (Diablotek 500W) died, a thermistor inside blew. My power supply was about 4 years old so I wasn’t sure if it was just old or had something to do with my overclocking. I bought a new PSU (Thermaltake 750W 80+ Gold) and installed it Jan 5th. I also ordered a new thermistor to try and repair my old PSU as a backup, which I now have and works just fine. Well I went to use my computer (which was on over night like usual) on the 16th and the mouse or keyboard weren’t working, also there was a “windows recovered from a critical error” message. I held in the power button till it powered down, a waited a few seconds and turned it back on.
The fans all came on and all the LED’s were lit but there was no “beep” and nothing came on the display. Plus I couldn’t turn it off, not even by holding in the power button. I had to flip the switch on the PSU to get it to shut off. I messed around with it for about 20 mins removing all sorts of things, eventually it started working again but I’m not sure why. Well even though I got it to boot it kept freezing (in windows) after around 10 mins.
I went back into the BIOS and set everything back to factory and that seemed to fix everything. I figured I’d wait a week or two before trying to overclock again just to see if the problem was fixed. Ofcourse it wasn’t though lol. It worked fine all week, I was playing mass effect all week with no problems. Then last night I passed out watching netflix, when I woke up this morning I had the same keyboard/mouse won’t work problem again, minus the “critical” windows message. Had to hold in the power to get it to shut off again, then when I turned it back on the same problem came up, no beep, no display, holding power won’t shut it off but all the fans and lights come on. I flipped the switch on the PSU and left if off for about 10 mins, then tried again but still had the problem.
So I unplugged everything from it and cleaned a space to my table to start taking it apart. I came back to it to move it to the table but decided to give one more go before I start taking things apart. I pluged in the power cord and the HDMI cable and it came on, no problems. I’m guessing unplugging the power cord let all the power drain out of it where just flipping the switch to “off” didn’t quite do the trick. Still doesn’t answer why this is happening in the first place though.
Hoping that this is not an issue with my motherboard due to my overclocking I swapped my new Thermaltake 750W PSU for my old (and now repaired) Diablotek 500W PSU. The PSU is the only hardware change I’ve had since September.
I’ve been running the computer with the 500W PSU for a couple of hours now with no issues. Now I’m just going to leave my pc on and see if the issue comes up again. What do you think? Is it possible I screwed up something when I overclocked, or when my first PSU died it screwed something up? Or maybe it’s an issue with the new PSU? Any help is greatly appreciated.
AMD Phenom II x6 1090T Black Edition
Asus M4A89GTD-Pro Motherboard
Nvidia GeForce GTX 660
PNY Dual Channel 4096MB (2x2048MB) PC12800 DDR3 Memory - 1600MHz, Non-ECC, Unbuffered
Thermaltake Water 2.0 Extreme cpu cooler
Windows 7
PSU 1 - Diablotek PSDA500 DA Series ATX Power Supply - 500W
PSU 2- Thermaltake Toughpower 750W Power Supply Unit - ATX, 80+ GOLD, Modular
120GB Intell SSD
500GB SATA Hard drive
80GB IDE hard drive
sata dvd drive
Thermaltake Chasar A71 case
Case Fans: one 120mm rear fan
One 200mm Front fan
One 200mm side fan
Windows 7
120GB Intell SSD
80GB IDE hard drive
sata dvd drive
One 200mm Front fan
One 200mm side fan
