Do they sell something like this (I would prefer Bitspower, but another quality brand will suffice so long as you guys endorse it) in compression - http://www.sidewindercomputers.com/big14shsianf1.html
I know I can get rotary fittings, but for my own sanity I would prefer fixed ones because there is no chance of leaks at the point where the direction changes, and I can't see or have found a way to fix the rotary fittings at the rotary point if something goes bad. It just looks like you have to buy a new fitting.
I know I can buy things like this, which I will, but was hoping to find an entire fixed fitting as it would cut down on connection points / places with the potential for leaks:
http://www.sidewindercomputers.com/bishsi45deg1.html
http://www.sidewindercomputers.com/bisish90igad.html
Furthermore, FrozenCPU doesn't seem to list anything as Shining Silver. They have this listed as silver - http://www.frozencpu.com/products/6...on_Fitting_-_14_Walled_Tubing_BP-CPF-CC3.html
I want ones that are the chrome look, but NOT the ones that are the silver plated to work as a biocide (http://www.frozencpu.com/products/2...lver_Plated_BP-SLCPF-CC3.html?tl=g30c409s1608). Just want to confirm silver from FrozenCPU is the same as Shining Silver from Sidewinder.
Thank you!
Thank you!
