- Jan 28, 2009
OK, I've got a "full tower" case with limited internal space inside....not the best laid out for W/C'ing at all....despite that, it's going to hold internally a full W/C'ing setup.
First, some hardware specifics:
I've got a Q6600 @ 3.6GHz @ 1.35V, NB @ 1.5V (on an Asus Maximus Formula MB), 4 x 2GB Mushkin DDR2-1000 Redline RAM, an ASUS HD4870 video card (and a second is coming next month for Crossfire), 2 x 500GB WD hd's, etc.
W/C'ing components include:
Swiftech GTZ cpu block
EK S-Max NB block
Pump #1: DDC 3.2 w/XSPC top
Pump #2: DDC 2 stock top
TFC 240 rads X 2
TC 120.1 rad
HD4870 full cover blocks.....brand undetermined right now, possibly EK, XSPC, whatever strikes me as best bang-for-buck when I buy them.
Swiftech MicroRes
3/8" X 5/8" Primochill LRT tubing
Barbs will be Bitspower/DD FatBoys and will use Bitspower 45 degree fittings as necessary
This is how I've come up with how to loop the entire shebang with one loop:
The TFC 240 on top is mounted in the case's top, the bottom TFC 240 is mounted on the floor of the case; the PA 120.1 is mounted on the rear 120mm fan exhaust area. Fans will be Scythe S-Flex "G" fans on the TFC 240 rads and a Zalman F3 on the PA 120.1....all speed controlled with a fan controller.
(FYI: The second pump will essentially be invisible as it'll be mounted above the TC 120.1 rad along the top corner of the case....won't be able to see it without laying down flat and looking up into the rear corner of the case.)
Horrible? Will certainly be much easier to loop as a single rather than trying to split it into two with two radiators...........
EK S-Max NB block
TFC 240 rads X 2
TC 120.1 rad
Swiftech MicroRes
