- Mar 31, 2005
- Stealing your megahurtz at night
I have an Antec 900 that my water cooled quad rig is in, but I have a few complaints about it, even after owning it for a year. I was at a local Fry's Electronics a couple weeks ago, just browsing around, when I came up to the Antec cases. I noticed the newer Antec 900 (might be 900 Two?) has a much less restrictive design on the front bay covers. It looks very similar to the one at the top 200mm fan, more of a diamond weave or honeycomb shape, where the ones on my 900 are just a countless number of tiny holes. As we all know, holes like that actually restrict airflow by quite a bit, and tend to create unneeded noise. I was hoping that I might be able to find replacement covers like the new style, but haven't been able to find much. Anybody have any ideas?
There are a few more things that I am working on as well. I plan to replace all of the blue LED Tri-Cools with something with a green LED instead. I was thinking about some Yate mediums on my Rheobus, but I am not sure how those LED's will react to the voltage drop (they will probably be at around 7V most of the time). You guys are probably wondering what I am thinking, trying to quiet it down by switching the front bay covers and changing out fans, with those Delta screamers in my sig, but most of the time they run at around 5V or so, and really not that loud. I might crank them up a bit when it really gets warm, but I try to keep them as quiet as possible. I am actually thinking about replacing them with something a little quieter, like some Panaflo's or SanAce's.
I have already cut the mobo tray for better wire management, but the cable that runs my HDD's is still semi visible near my water pump, as well as the SATA cables. I plan to flip the HDD's around one of these days (when and if I can get some time) so that the connections are toward the fans, instead of out the back of the drive bays. Since my Neo 500 PSU has a rear exit 80mm fan, I'm not going to worry too much about cutting a hole to flip the PSU, just yet.
Anybody have any other idea's that I'm not thinking of? I will likely break the entire system down when I do my annual loop tear down, cleaning, and inspection, and get the inside of the case painted black, since I don't care too much for the silver. Pretty much everything I am doing to the case at this point is purely to try to reduce noise or aesthetic. If you have any ideas, I would love to see them.
