- May 12, 2015
I have mostly all EK fittings on my loop and i noticed the end you tighten around the hose slices into the tubing.. even if you dont tighten it too much, when you take it off like 1/3 of the tubing is sliced into.. i can imagine taking the tubing off many times it will eventually cut into it too much and cause issues like leaks and hoses blowing off by being cut too much specially when tubing length is short..
I have two Bitspower fittings since microcenter ran out of the singles for EK, and the bitspower doesnt cut into them. If you feel the ring inside its smooth and rounded, the EK is sharp as hell. Kinda sucks if you think about it, as these fittings are overpriced and expensive to be cutting into your tubing rendering it useless over time.. Anyone else have EK and notice the same thing ? Even the barbed end where the hose pushes onto is sharp and cuts the tubing inside...
