- Jan 13, 2013
- Orange County, CA
Hey guys, I'm trying to gear up for the folding CC starting in just a few days now and I'm looking at my systems, thinking about just how much more I was able to produce during the cooler months when I was able to run a full 200-300mhz higher CPU clocks without heat trouble, not to mention the NB speeds being higher too. I do plan on going with a custom liquid setup for at least my FX chip at some point in the future, but for now I need to find out if anyone thinks I have anything to gain with something not outrageously pricey, widely available and possible to install by the weekend. Right now, here is the basics-
FX 8350 folding @ 4.2ghz
Xigmatek Gaia with 72cfm Rosewilll push/pull fans
22c room temp peaks at 56c CPU temp
(Source 210 case, plenty of airflow in and out)
X4 965 folding @ 4.2ghz
Xigmatek Gaia with second stock fan in push/pull
22c room temp peaks at 51c CPU temp
(Themaltake Commander case, okay case flow)
X4 965 folding @ 3.9ghz
Xigmatek Loki single fan
22c room temp peaks 52c CPU temp
(HTPC most of the time, not a ton of case airflow)
Would anyone imagine I could do much better than what is there now (Gaia generally compares to the 212 Evo) without spending a ton of money or seeing less than one or two degrees at most shaved off for all the effort?
