Well it has been a long time since I have built a new rig and although I have been reading up I know you guys are much more in tune with what is good and bad. That being the case I would appreciate your comments on the rig I plan to build in March.
Motherboard
- ASUS P5B Deluxe LGA 775 Intel P965 Express ATX Intel Motherboard
Processor
- Intel Core 2 Duo E6600 2.4GHz 4MB Cache 1066MHZ FSB
Is there any real reason to instead get a:
- Intel Xeon 3060 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor
I would like to clock to 3.6+
Cooling
- Tuniq Tower 120 P4 & K8 CPU Cooler
Memory
Based on evilsizers comments I am going to go with:
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Case
- Antec Performance One P180 - I already own this case.
Hard Drives
I would like to take advantage of the MATRIX raid that is available on the P5B Deluxe. I am planning to get 2 of the following (each split first 50gig raid 0, other 200 raid 1):
- Seagate Barracuda 7200.10 (Perpendicular Recording) 250GB 7200 RPM SATA 3.0Gb/s
Are there better drives I should get instead to gain even better performance?
CD ROM / DVD ROM
I have a Sony 18x DVD-RW I plan to move, I don’t have a link.
Graphics Card
Trying to decide what to do here, depends on cost and availability
One of these:
- 8800 GTS
- 8800 GTX
- R600 card from ATI….if they ever get released! This is one of the biggest things preventing me from pulling the trigger on the build (sigh!)
Not sure if I should be concerned about my case choice as far as fitting a card in it. I will measure before making a purchase.
Power Supply
*** I would appreciate your recommendations here ***
I know that that the p180 case has limited room at the bottom so that is a factor but I can measure the space and compare that to any ideas offered to help me pick. So if it fits I am thinking:
PC & Cooling Silencer 610 EPS12V
(Thank you batboy)
Sound Card
- Creative Sound Blaster X-Fi XtremeMusic - I already have this card
Thanks you in advance for your input!
Motherboard
Processor
Cooling
Memory
Evilsizer said:well since psu's are covered here. BB touched on ram some but here are some i am looking at to replace the current 2gig kit i have.
these are D9 based ram from gskill
http://www.newegg.com/Product/Product.asp?Item=N82E16820231065
these here are proMos based ic's ocing just as well as some of the D9 ic's. the promos are maxing out about 30mhz lower then d9's are.
http://www.newegg.com/Product/Product.asp?Item=N82E16820231087
Case
Hard Drives
CD ROM / DVD ROM
Graphics Card
One of these:
- 8800 GTS
- 8800 GTX
Power Supply
(Thank you batboy)
Sound Card
