i have a aquaero 6xt w/remote and also have the aquaero 6 pro,my question is will the same remote work for both aquaero's?
if i were to use both in the same build,would i be able to control both without interfering with each other?
while the 2nd aquaero is an extra one and really have no need for it,i was just trying to possibly put it to use,,as its a shame to just put it away and not use it.
any advice is appreciated
thanks...
thanks...
