Get colored tubing, dyes inhibit water loop performance and stain components.
Distilled water + Kill coil + Pt nuke and colored tubing is the way to go.
When you buy the tubing it will tell you if it is UV reactive or not.
Get colored, or paint, the hard tubing.
Would I need dye to make that color I was thinking the ice dragon white and some uv blue
Is there liquid in those tubes? That is the color as it would look under black light.
The tubing color is a UV reactive blue.
Again, dye is bad.
