I run an i7-6700K in a Phanteks Enthoo Luxe case with an Arctic Liquid Freezer 120. I have a temp probe in front of the Rad and my case's internal temps are usually around 2c over my room's ambient temps so my airflow is pretty good. My CPU is running a 4.6 GHz OC across all cores with a VCore of 1.36V. Any less voltage causes stability issues when torture testing with Prime95.
I am using a PWM CPU-based fan port on my motherboard to power the push-pull cooler fans. My cooler is able to keep the CPU at the internal case temps with low fan RPMs when the PC is under very light loads (light content web browsing or video streaming). Heavier loads (like gaming or a full Anti-Virus scan) raise my CPU usage, ramp the fans up, and the resulting temps spike up to the mid 60s with the internal case temp around 26c. I find this performance to be acceptable and the noise level is low.
When I torture test my PC with Prime95 my temps run up into the low 90s, which is a bit too high. How much lower would my torture temps be if I switched to an Arctic Liquid Freezer 240 or 360? Both of those radiators are much thinner than the radiator I am running now. My 120 mm radiator is 49 mm thick. The 240 mm radiator is 38 mm thick. The 360 mm radiator is 27 mm thick. I am not interested in a custom loop and I'll stick with what I have if the 240 and 360 CLCs are not any better than what I have now.
Thanks.
Thanks.
