Currently have it at 4545 MHZ in Bios, on CPU-Z it says its at 4560. LLC has only 3 options for me Auto, Disable, and Enabled. Maybe the EVO/PRO version has those so mine doesnt. Thats probably why it has 5 options in the descriptions options ranging from (1)Low-(5)Extreme.
So far I have gotten my OC stable. Im wondering if my Voltage is perhaps set too high. In the program AI Suite II provided with my mobo it reads it my Voltage at 1.536 HW monitor seems to be just rounding it up.
I have read on the forums that 1.55 voltage is the highest you should set the FX-4100 keeping it under 70 C. Also saw someone else state 1.52 should be the highest the FX-4100 should be at, but that was one person and I cant find any other info on that to back up his claim. Well I have it at 1.46875 and with LLC enabled my Vcore is at 1.536. I managed to get it stable at this Voltage with my temps maxing out at 61C during stress testing with the following OCCT, Prime95 Blend test, Linx, Intelburnin and AMD Overdrive. It idles around 35-40C. So are my voltages acceptable? Or should I lower them back to 1.43 in my BIOS so it stays at 1.5-1.52.
I tried to OC my memory with no luck. I couldnt even tighten my timings at all. When raising my Voltage from 1.5 to 1.65 on my Dram. So I left it as is.
EDIT: That CPU-Z CPU Tab screenshot is was taken before I set it back down to 4545, after stress testing and showed it unstable, All the other tabs are correct information. So please excuse that part. Everything else is correct though. The bIOS is where my real numbers are at. I accidently cut out the bottom of the memory tab when uploading but it is all at stock except for its at 1(T) not 2(T). 9-9-9-24-41
