I have recently began experimenting with overclocking my system again, for what I think is the first time since I rebuilt in this new case. I have been running an AMD FX-8350 on a Gigabyte GA-990FXA-UD3 r4.0 motherboard for the past 4.5 years, with basically no problems. When I last tried overclocking, I was able to get my CPU up to almost 4.7 GHz, cooled under a Hyper 212 Evo in a Corsair 200R mid-tower. Now I am using a Corsair H100i GTX that I bought second hand, inside a Raijintek Thetis case. The case is a bit unorthodox in that it features an inverted layout with the PSU in front, and I am pulling fresh air into the case through the radiator to cool my CPU.
Under stock conditions, the system runs fine and only maxes out at around 45 degrees or so while gaming. When I tried to reapply my OC profile I had saved from a while back, the CPU initially idled in the mid 40s. When I started an Aida64 stress test (no GPU load) the CPU temp warning on my mobo wouldn't stop screaming and the reported CPU temp was around almost 80ish degrees, package temp around 65... The fans also kicked up to jet takeoff speeds. This was weird to me, considering I had set this to only around 4.4 GHz and I had previously gone higher. Right now, I am stable at 4.3 GHz with about 1.3v, at the stock 1.4v it gets a bit too hot for comfort... When I then tried stressing my GPU only, its temps were basically unchanged to what they used to be in the other case. This case only has one 120mm exhaust near the CPU and the PSU exhausting air, and the rad bringing in air at the top, which blocked a bit by the GPU.
Could it be that the VRMs are burnt out or something, or just too warm because of ambient case temps?
There has also been an issue with Windows locking up entirely, only letting me move my mouse, forcing me to hard reboot, but that happens at stock speeds as well so I wouldn't necessarily call that related (unless the motherboard is the problem).
