- Jan 22, 2003
Thats kool. If you dont want subambient temps then just forget about chillers all together. That coolit setup in the ALX really won't do much past a normal radiator. TECs are usually gain or no gain results. No middle ground. If the coolit device did what it was supposed to then that large radiator in the top of the ALX case would be defeating its purpose
From what you just said I would focus on getting a new case, one which would fit a good watercooling setup. At the same time look into a good watercooling setup.
For a TEC chiller to be your radiator you need a large one. There have been a handfull of projects where people had huge TECs on very huge heatsinks for chillers. Never heard any final results. Looked like a ball of wax IMHO.
If you have a very good watercooling setup you can always go with blocks that are TEC friendly, i.e., can be used with TECs with hold-down plates etc. So in the future you can have a normal TEC setup.
