- May 17, 2004
- Belgium, long live teh beer!
Ok, I've got 2 questions here...
First, is Artic Silver Ceramique thick enough to act as an adhesive for tiny alu heatsinks for the NB and SB.
I found an old P1 HS lying around wich I'm going to use for the NB of an old P3 gigabyte mobo, and the stock NB HS is going to be used as SB HS.
They're both tiny, the P1 HS is 40*40MM and the stock NB HS is 30*30MM.
The motherboard doesn't have through board mounting holes for the NB, so its gonna have to get adhesived to the NB, same for the SB.
If ASCeramique isn't thick enough to stick, how can I make it?
Second, cleaning alcohol, the northbridge chip with lots of residue left and the PCB around it.
Is cleaning alcohol dangerous for any plastics around? What about nail polish remover? (Since its the only thing that I currently have in the house)
Thanks in advance. I wont be able to reply to this thread for the rest of the day, only this evening or tomorrow (talking about the brussels, copenhagen,... timeline)
