1. We know there are two temps related to amd cpu that we concern ourselves with.
2. In HWMonitor Free we normally see cpu temp and package (core) temp.
3. Cpu temp also known as 'socket' temp should generally be less than 72c.
4. Package temp also known as core temp should generally be less than 62c.
5. Because we use HWMonitor and not generally that AMD program you would have to know which of the temps that program you are using is actually reporting. Then the two temps in #3 and #4 above apply as max temps.
RGone...
