I have two of these motherboards so I decided to test a Ryzen 3 2200g ( APU) in one of them. It previously had a Ryzen 5 1400 in it and all was well.
Updated the bios to 4.50 , tested with the 5-1400 and all was normal. Could overclock as usual etc.
Installed the Ryzen 3 2200G, Found the drivers and updated and got the normal good graphics for my Monitor 1920X1080...
fyi... Clock control goes away, or I haven't found it yet, when the APU /CPU is installed, in this Motherboard. When the Ryzen 5 1400 was in there, overclock controls where as usual...But the clock was around 3.5 ghz.
First thing I noticed was Ryzen Master would fail to load quoting a couple errors. Then I noticed that Passmark 3d test DirectX 12 fails.
I reloaded the cpu drivers again, then the Passmark directX 12, 3d test worked. Ryzen Master still fails to startup. I have built Eight Ryzen PC's and this is the first issue with Ryzen Master I have seen.
Just putting this out there for information, and feedback if someone hears of a cure for this.
