- Jan 12, 2012
Yes, water temps were in the -1 to -2 c range I'm sure there is more in it when I can get -10 to -15c water on it.
As am I.I am so looking forward to seeing it at 6.0!!!!!!!!!!!
Both are pretty good choices right!?!
Going to need some more specifics here...
...another thread about choosing a 990FX AMD motherboard.
http://www.overclockers.com/forums/showthread.php/752902-Help-choosing-a-990FX-mobo
bob4933 writes in that thread about his move to the Sabertooth 990FX R2.0 from the Asrock KILLER 990 board. He straight up says the Sabertooth 990FX R2.0 is better for him than the KILLER was.
The problem for me is that the FX Bulldozer and Piledriver series of cpus has been out now for nearly 3.2 years and most of us that help in the AMD forum sections have had mostly 8 core processors in use for that entire 3.2 years. If you look at the overclocks of the say johan45 and mandrake4565, you will see some pretty freeken HI overclocks and benches. Not even on LN2 or DICE and speeds on FX-8xxx and FX-9xxx in one situation that are touching the 6.0Ghz speed range. THEN they take the same board and run day in and day out and have now for at least 2.5 years. Bassnut has his system running at 4.9Ghz daily with an FX-8350 and all of these daily drivers are using ALL cores when clocked up and not just one half the cores but ALL the cores when running the daily big numbers greater than 4.7Ghz. Each of these guys has gone thru the lesser boards to settle on either the Sabertooth 990FX or the CHV and have had the boards in service at very high daily clocks and still when cold weather comes they move their radiators into the outside cold and again begin to *thrash* their boards and cpus relentlessly.
That is the measure of a motherboard of any kind to me. People that I actually know run fast everyday AND will push their systems to the very outer edge of realistic and the stuff just keeps on a-ticken. That is what determines my most favored motherboard. Not price or color but consistent results.
RGone...ster.
Good post mate. I wish I had some cold air to place my rad in. Can't seem to find any in S. FL
That reminds me, its officially benching season in michigan
Is it sort of like a hunting season or something? Do you have to purchase a license to participate?
Hehehe.
RGone...ster.
I know my Rev. 4 UD3 has LLC. I set mine to EXTREME and there is +/- .01 variance at 5.1GHz under load.
Ahh.. passive aggressive back-handed compliments. How very pompous of you.
Huh? Im just suprised a UD3 can do that. Guess you got a good chip as well. I couldnt get past 4.7 with even an extreme 9
Well when you get the CHV-z the board will not longer be the hold-up. I have covered a lot of ground looking at CHVs for 4 years now and the board was never an issue. Cooling and cpus and ram having been the hold-up. There were some problems on the CHV non-z with the NICs failing and Asus of course would fix all sent to them for that issue and did. A few issues with sound a couple of years ago, but NADA about not overclocking the PEE out of a cpu.
RGone...ster.
