Hi. I bought an used ASRock G31M-S motherboard (s-775). My cpu is Q6600 core 2 quad (FSB1066). I built the system. The problem is that when I push the power-on button of the case, the system don't post the first time. Only the green power led is on (the ssd red led is not lighting). If then I push the reset button of the pc case, then the pc boots normally every time (or if I push the power button constantly some seconds to close the power, and then push the power-on button again, the system boots normally). When I shut down pc, the windows shut down properly and the monitor stop to display, but the cpu fan still spinning.
On motherboard the OC800 jumper has shorted pin1-pin2. Also FSB0 and FSB1 jumpers both has shorted short pin1-pin2. When I moved the jumper OC800 from pin1-pin2 to pin2-pin3 the system operate normally. I have normal boot and normal shut-down. Everytime. It was the right action? To short pins 2-3? Or not? May I had short pin2-3 on FSB0 or FSB1 jumper? What these jumpers FSB0 and FSB1 doing if I short pin2-3 (from 1-2?). The manual https://download.asrock.com/Manual/G31M-S.pdf
is not explain about the jumpers FSB0 and FSB1. Also I didn't find anything about cpu with FSB1066 If I must short pin2-pin3 at OC800 jumper.
In windows and in bios the cpu has stock frequency (2,4GHZ) if i short pin2-pin3 in OC800 jumper.
Please help me. Thank in advance!
