The overclock should only apply when entering windows not at post.
Hit f8 at post then safe mode and run afterburner and reset it
Wait........ Your saying you get no POST?????????????I tried it with the Bios selector on both sides and it still didn't work. The screen stays black the entire time, and only the mouse and keyboard lights turn on a couple seconds after the motherboard beeps.
The board gives me an error code 26 as well. Google doesn't give me too many accurate results. One result was on the EVGA forums saying that the person had a stable overclock but this error code would randomly give him the same beeps I would get. Eventually he switched out the motherboard to an Asus. The difference with my situation is that my 5870 boots normally, but my 290 does not. Should I try to clear the CMOS once more? I'm guessing the best way is to unplug the pc, remove the battery, and wait 10 minutes?
Reset CMOSYes no POST whatsoever. I start up the computer, motherboard does a medium beep, followed by a beep-beep (three beeps total), and then the fans slowdown like normal, and my mouse and keyboard lights go on. The EVGA x58's error code says 26 as well.
Reset CMOS
Are you able to run MSI AB in safe mode considering there are no or generic VGA drivers?The overclock should only apply when entering windows not at post.
Anyway, if your 5870 boots fine, but not the 290 anymore, it seems like the problem is in the GPU. Test the 290 in another PC would be my next step.
Strange how the video jsut died like that from overvolting.
Last week I was running a test run on this sapphire 290 @ 1.3v and left it all night stress testing no problems.
Sure you had fan at 100%?
I have a Prolimatech gpu cooler on it and I can't change the fan speeds. However while benchmarking, the gpu did not run hotter than 65C. Perhaps something got too hot other than the gpu die? I had all the vram heatsinks and mini heatsinks installed properly though. I also couldn't run the card for more than 10-30 minutes without it shutting off, I'm not sure if that's enough time for something else to fry. Although it didn't shut off while idling, just benchmarking... I don't know anymore to be honest, it's a mystery.
I also tried it in another computer and the computer had a black screen but I also saw its keyboard light up and then the cd drive started to spin. I think it booted to windows but it wouldn't show anything on screen. There also weren't any beeps or error codes but that's because the other computer's motherboard was different.
Overvolting can kill a chip despite heat with low temps. Or maybe you blew a cap or something. Inspect the card
