ASUS A7V333 - Athlon XP 1800+ - A Few Quick Questions
I have had my PC for a little over 2 years now. I spent some pretty good cash to buy a killer system at the time. It is now time to overclock.
The system is a good quality system. My friend selected the components for future overclocking and he worked at the computer store.
I bought a CPU (Computer Power User magazine) dedicated to modding, so I understand quite a bit. I am figuring this out, but I need a little bit of help. I have an engineering background, so I am technically proficient.
First off, I will list my hardware:
Motherboard: ASUS A7V333
CPU: AMD Athlon XP 1800+ (Thoroughbred or Palomino? I dunno)
Graphics Card: nVidia Geforce FX 5600 Ultra (upgraded from the Radeon 8500)
RAM: 1 x 512MB PC 2700 (333MHz)
CPU Fan: Global Win. I dunno what model number.
Case Fans: Four case fans in a Lian-Li case, cranked to High! Good circulation?
Power Supply: Enermax, I think a 350 watt? Maybe only 300 watts though? With a UPS to prevent power surges and brownouts.
Sound Card: Audigy
BIOS: Fully updated to the latest version 1018.
Second I will list what I have done:
1.) I pushed the FSB to 142 until it crashed booting into Windows XP.
2.) I progressively pushed the multiplier as high as possible to 12.5 to get a total of 1775MHz.
3.) I nudged the CPU Voltage up to 1.775 volts from 1.75 volts.
Third, using ASUS PC Probe (monitoring utility), I observed the following:
1.) CPU temp is no higher than 52 degrees celsius, which is pretty safe?
2.) Motherboard is 35 degrees celsius.
3.) Fan RPM is 5800... does this even matter?... lol
4.) Voltage. Confusing to me... but I will write what I see:
Questions:
1.) Even thought I calculate the new clock speed to be 142*12.5=1775MHz, it is only showing a clock speed of 1.63 GHz in my System Properties. Why? Is the CPU clocked at 1.63 GHZ, or 1775MHZ? Is this just some kind of glitch in the report?
2.) Why is my multiplier maxed out at 12.5? Is this a limitation of the BIOS? Or can I unlock the motherboard or CPU? I remember buying some conductive paint stuff, that I was told I need to unlock my motherboard. I think that the new BIOS unlocked my motherboard though? What do I need to do, to push this unit into the stratosphere?
3.) Why is my vCore reported at 1.84v when I have only nudged it up to 1.775 volts in the BIOS?
4.) How do I tell if have an Athlon Palomino or Thoroughbred? Can I tell with the stock vCore of 1.75 volts?
5.) What are all of the voltage readings? I know that vCore is to the CPU, but what about the others?
6.) How fast should I be able to get the FSB? 142 is not that high, is it? I have an ethernet card and the Audigy on the PCI bus. I have heard that Creative soundcards are bad for their FSB, is this true?
7.) I am considering getting a watercooling unit. Any suggestions? I know that getting a faster CPU would be better, but I can use the water cooler with a faster CPU at any time.
I don't want to spend a lot, otherwise I'll just get a Barton. I want to push this chip for now and then grab something faster when the faster cheaps are even less expensive.
After overclocking my CPU, I want to overclock my graphics card and max out my RAM. The articles and guides are in my CPU PC Modder magazine. I have the basics of what I need to do with the latency and so forth, but I will probably have a few more questions. If you have any suggestions, or comments I would much appreciate them.
Thank You for your assistance!
Sound Card: Audigy
13.376v +12 volts
5.08v +5 volts
3.392 +3 volts
1.84 vCore
5.08v +5 volts
3.392 +3 volts
1.84 vCore
Questions:
