- Nov 14, 2004
- Puerto Rico
Well at 2.4GHz and 1.65v it ran for at 'least 4 hours before it froze (and I had a video looping in the background as Prime ran and I did some heavy browsing so that test was a bit overboard)... but it was running hotter than I'd like. Basically 48-50C all the way thru even though temps got a degree or lower here tonight than my earlier test (where it ran 6 hrs w/o crashing at 2.3GHz and 1.50v).
Not sure what else to try anymore, think I may just stay at 2.3GHz and be happy... At 'least for now, I don't have the time to keep running so many stress tests when I need to get the machine back to normal use. I like the temp headroom I had at 2.3GHz anyway, 44C gives me a margin of error for the summer season or increased heat from the video card (even though it's got an NV5).
I've got one last question, it's something that just ocurred to me... What have you guys set the AGP/PCI speed to when OC'ing? Should it just be left at Auto or 66.6/33.3? I wonder if maybe it's crashing on me at higher speeds (HT of 267 versus 256) because the PCI lock is not enabling itself...
I've got it set manually to 66.6 so I was just curious if it should work that way. It could very well not be the lock's fault, from the way it managed to be a lot more stable with higher vcore I'd say that supports the fact that I'm just hitting the roof here with my cooling and room temps.
Anyway, 500MHz/28% OC ain't too shabby for silent air-cooling.
Edit: Went back and read your FAQ, wow, either this thing (and the amount of A8V info over here in general) has grown or I missed a lot of it back in Oct.-Nov. when I was doing my research.
Either way from what you've said a setting of 66.6/33.3 should be fine. Guess I've just hit my headroom, hrm. I suppose I could lower the multi and stress test with the 267 HTT (at a speed lower than 2.4GHz) but knowing whether it's the processor that's hitting the wall or the mobo (in it's way of handling the Winchester) doesnt' really solve anything.
Edit #2: So I couldn't let it go... Must get to at 'least 2.4GHz! Anyway, I'm gonna try some runs with memory timings on Auto which will set 'em pretty tight I think, I remember some people with Ballistix actually being more unstable with looser timings. I doubt I'll uncover anything since I'm not running it high either way, but it shouldn't take long to crash (w/o 1.65v+) if it doesn't solve anything.
Also I was reading the AGP aperture comments, I've been having mine set at 256mb due to something I had read before regarding my BFG 6800 OC but I'm wondering if this is a big mistake?
