- Jan 26, 2012
- Dirty Jersey
Hey all, I recently broke out my Commando again just for fun and keep having the same problem. Whether I use my P4 920 D or my E6300 it freezes at different times while in the O/S. It never did this before but my son was using the computer yesterday and just locked up. I am using a hard drive that was giving my father problems before I replaced it but I found it was a virus and he wanted a bigger HDD anyway. Can it damage sectors in the HDD and cause it to malfunction once in a while?
Setup: (Keep in mind it's just to play with)
Asus Commando w/ either P4 D 925 or e6300
500 watt cheapo galaxy psu-tested with multi meter and psu tester. works fine.
2 GB OCZ Platinum 2.1V 5-4-4 ram
evga gtx 650 gpu (the mini card)
WD Caviar black 250GB or so HDD
Optical drive
All on a Lian Li test bench and water cooled
What I did:
swapped cpu's
resat cpu
swapped RAM and tried different channels
removed CMOS batt and waited
reset BIOS w/ onboard button and jumper at separate times obviously
pulled all parts off of the mobo and added 1 piece back at a time and ran with minimal hardware needed
flashed the BIOS
Reinstalled all drivers
I do not currently have another HDD to try but everything works like said but locks up at different times whether I am loading the cpu or it is at idle.Also all BIOS settings are at default. Any help is appreciated.
Optical drive
What I did:
swapped cpu's
resat cpu
flashed the BIOS
